Xiaomi Redmi Note 10S
1695 2 2022-2-2
Curlewis
South Africa
Hi, i see on the compatible list the Xiaomi Redmi Note 10. Does anyone know if the Redmi Note 10S will work?
2022-2-2
DJI Stephen
Hello there Curlewis. Good day and thank you for reaching out. I hope that our fellow DJI co pilots who uses the Redmi Note 10S can give out the best recommendation and information with regards to this matter. Thank you.
2022-2-2
warnersmith323
Bangladesh
There's a good chance the Xiaomi Redmi Note 10S will be compatible as well. Here's why:
Many sources confirm that the Redmi Note 10 and 10S share many components, including the display size and resolution https://gsmserver.com/lcd-compatible-with-xiaomi-redmi-note-10-redmi-note-10s-black-without-frame-original-change-glass-m2101k7ai-m2101k7ag/.
They both run the same operating system (Android 11) https://www.amazon.com/Factory-Unlocked-Compatible-Verizon-International/dp/B0977HR8JT .
Given these similarities, it's likely the Redmi Note 10S  will function the same way as the Redmi Note 10 in regards to compatibility.
However, to be absolutely certain, it's best to double-check the compatibility list for any specific requirements. You can also try searching for "[Redmi Note 10S compatible with + what you're checking compatibility for]" to see if there are any known issues.
4-23 21:49
