S-BUS and switch mod // ISSUE
492 0 2022-2-2
brieucLM
Hello,
Does anyone have a problem with the mode selection during S-BUS transmission?
I explain, when I map channel 6 (change mode between 1-2-3) on my TBS Tango 2, (on a 2 position switch (!SF) -100 / 100), the mode selection is blocked on one of the 3. If I switch from mode 1 to mode 2, the mode changes 1 second to mode 2, and back to mode 1, 3-4 seconds later.
Before mapping the switch to my radio controller, the mode selection works fine.
The solution found was to downgrade the firmware (and upgrade) after.
The factory reset does not work.
Has anyone encountered this problem before? Has anyone found a solution to have a working mod + switch channel that doesn't bug the Ronin?
thanks a lot,
Brieuc
2022-2-2
