lumix s5 + 24-105mm + ronin S2 or SC2 ?
594 3 2022-2-8
Canard1234
Hello
Are Ronin S2 and SC2 compatible with Panasonic Lumix S5 and S Pro 24-105mm Macro OIS lens to use the focus?
Thanks in advance !
2022-2-8
Indio
Flight distance : 303373 ft
Austria
here you will find your answer:
https://www.dji.com/support/compatibility
2022-2-8
Canard1234
Indio Posted at 2-8 07:06
Yes thanks, I had already looked at that page.
I know that the S5 is compatible with the SC2 / S2, but I don't know if the 24-105mm lens is also compatible for the focus.
I saw that there was compatibility with the S1 + the 24-105mm + the SC2 / S2, but I couldn't find a page that specifies the compatibility between the SC2 / S2 + Lumix S5 + the 24-105mm.
2022-2-8
Canard1234
The Lumix S 24-105mm and the 50mm works, the question is solved.
2022-2-26
