No Original Thought
Flight distance : 1364209 ft
If you are on Android then you can copy images into Android/data/dji.go.v5/files/DCIM/OriginalFiles/Photo
Anything in there can then be selected as media in the DJI Fly editor - obviously they'll need to be in the corretc file format, so JPEGs defintely work. So you could create a title/end screen image in some other software and then copy that file to the location above and use it in your DJI Fly edits.
Under Original Files there is also a Video folder (and a PanoPhoto folder) so you can theoretically copy video files there and use those in your DJi Fly edits as well.
As for stickers.. I haven;t been able to find where the app stores those, but maybe if you try copying a PNG file ito the Photos folder you will be able to add it as an overlay - Ihavent really played arond with the edit functionality in DJI Fly, so I'm not familiar with how flexible it is when adding stickers or image etc.
Hopefully this will get you started, though...
-N.O.T.
