fansfe82067d
1. Overheating problem
- Rarely a problem for most users in real-world situations. FW updates are improving efficiency but at the end of the day, tiny cameras with powerful processors are going to get hot - laws of physics.
2. front lens which is not removable
There are all sorts of lens protectors from 3rrd parties. Personally I keep a UV filter on mine. I think it would be been difficult within this design to make a removable front lens, however.
3. battery which is not water proof
The lower module has various openings - if these had been sealed it would have made the camera larger. You can get varioius waterproof housings. While the needs of minorities must be respected, I don't think most users need the full kit under water.
4. cannot directly charge main unit directly
You can with a quite cheap 3rd party add-on.
5. extra reserve batteries are much more expensive than Osmo Action 1
They are not just batteries. The whole design concept would have needed to change to accomodate just a plain cheap battery. Most users would simply carry a power pack if they needed it. (I never have).
6. SIM card slot on battery unit instead of main unit. The transfer of files into SIM card can be quite long and annoying
File transfer seems in line with expectation here - and remember, as the internal memory is formatted after transfer, then you want the transfer to be sure to work, rather than super fast. Of course you can transfer direct into your PC unless you filled the memory away from home. A card sliot in the main unit would need waterproofing with attendant size increase.
7. No slot for external microphone
It takes USB audio devices - input and output - with no adapter required. You can attach a cheap 3rd party USB adapter to use non-USB devices - no need to pay a lot of money to DJI for that. The Action 1 also needs an adapter, for any type of mic, so the Action 2 is ahead in that respect. And it handles stereo mics very well, unlike the Action 1. And the built in mics are class leading.
Bottom line is that DJI marketed this as the Action 2 when it should have been the "modular 1" or whatever. It really has no connection with the Action 1, or indeed any other action camera. It's its own thing. |
