DJI L1 error creating folder
1744 6 2022-2-22
jmgl0003
HI all,
I have a problem with DJI L1 data. In three projects, when I go to execute the flight, I get a folder creation error. When I downloaded the data, the files are created in the root folder (fined.*). Because of the size of these files, I think it has saved the three projects in the same file. When I process it with DJI Terra I get an error.
Can you tell me if it is possible to separate the projects?
Here is the link in case you want to download them.
https://drive.google.com/drive/folders/1qgvDnxksk78NQP3UwLN2fp9Nv29ExFZS?usp=sharing
2022-2-22
RMAUVAR
Flight distance : 800043 ft
Bolivia
I HAVE THE SAME PROBLEM ALREADY WITH TWO MATRICES.
WERE YOU ABLE TO SOLVE THE PROBLEM OF CREATING THE FOLDER?
2022-2-24
RMAUVAR
Bolivia
falla al actualizar
falla al actualizar
2022-2-24
jmgl0003
RMAUVAR Posted at 2-24 12:45
[view_image]
I think that the problem is the firmware. I have a problem to upgrade the L1 firmware to 3.0... Versión. The matrice and controller are updated to the last version but the L1 not and it is a conflict
2022-2-24
jmgl0003
[view_image]
He visto la foto, eres de España?
2022-2-24
RMAUVAR
Bolivia
estoy en Bolivia estimado, si justo igual, en mi caso estoy con la version 2.4.falla la actualizacion a 3.01 llega a 32% 39% si la hago desde el mando, y si la hago desde la SD tambien termina con dos Beeps largos y tristes...
2022-2-24
RMAUVAR
Bolivia
hola, pudo solucionar el problema? He probado el nuevo firmware del matrice 300 y tambien ha fallado.
2022-3-16
