Density Problem
752 8 2022-3-7
sandy06
Austria
Hello,
I am using the Zenmuse L1 with an M300 to create terrain models. In my generated point cloud I always notice a decrease in point density in certain areas. The resulting DTM then has errors in exactly the same places. I have added screenshots of the point cloud and the DTM. Does anyone know of this problem or have any suggested solutions?
Greetings!
2022-3-7
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
Have you tried reducing the flight speed? Are the calibration passes carried out correctly?
2022-3-14
sandy06
Austria
Hello,
i have tried flight speed settings between 5 - 10 m/s. The distance of the flight strips was adjusted to the speed and does not exceed the maximum length. Regarding the calibration flights, I need to use terrain follow because I never work in flat area. In this case I cannot check the option Enable Calibration Flight.
Greetings
2022-3-14
fans3cf3ca7b
Flight distance : 154009 ft
sandy06 Posted at 3-14 22:30
Hello,
Hello, in this case you must do the calibration manually, before and after the mission
2022-3-15
sandy06
Austria
Thank you for your help fans3cf3ca7b!
Exactly, this function is not selectable during the flight with Terrain Follow. Is there any guidance on how I do the manual calibration flights before and after the actual flight mission?
2022-3-16
Panph
Flight distance : 5322589 ft
sandy06 Posted at 3-16 05:09
just take off manually with the flight plan selected and open in the map. Press that button to calibrate the L1 and then you're free to start your mission. When finished, do not return to home but take control of your drone manually and re-press the calibrate button.
2022-3-16
sandy06
Austria
Seems to have been a big mistake on my part. Thanks for your help. I will test your suggestion immediately!
2022-3-16
fans3cf3ca7b
sandy06 Posted at 3-16 06:16
Okay Sandy06, let us know how you did it.
Thanks
2022-3-17
sandy06
Austria
Hello,
thanks for the tips. Unfortunately it still does not work. The problems are still there.
Greetings Sandy06
2022-5-24
