djiuser_oG0k9Z9VCNtj
Czechia
DJI Stephen Posted at 3-10 17:03
Hello there AntDX316. I am sorry for the trouble this has caused and thank you for reaching out. Upon checking the mobile device ( Samsung S22 Ultra ) that you want to use on the DJI Go 4 application. I am sorry to say that the said mobile device is not yet recommended for these DJI Go 4 application. DJI suggests using a recommended mobile device for the DJI Go 4 applications for compatibility and reliability purposes. There is a possibility that the Samsung S22 Ultra will be able to work on the DJI Go 4 application. But however, since it's not yet optimized for DJI Go 4 applications we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Go 4 application when using it. For reference I will post a link where in you can check the recommended mobile devices for the DJI Go 4 application ( https://www.dji.com/downloads/djiapp/dji-go-4 ). In addition, please rest assured that DJI is continuously testing multiple mobile devices to be added on the recommended mobile device list for the DJI Go 4 application. Thank you.
Thanks for your information.
We checked with our engineers, we are working to make your device Samsung Galaxy S22 Ultra compatible with the DJI GO 4 app. Please be patient and multiple compatibility tests will be performed as soon as possible to ensure the usage stability.
If you have an urgent flight mission, we recommend you use a mobile device in the below compatible list to carry out the mission, instead of using this device to avoid the mission cannot be carried out due to compatibility issues.
For your Samsung Galaxy S22 Ultra, kindly wait for the next DJI GO 4 APP version.
We are sorry for the inconvenience caused to you. Thank you for your understanding and support!
