Nickthepilot
Flight distance : 35906 ft
Good morning
I did an oblique mission with my DJI M300 RTK using DJI Lidar camera (so total of 5 flights), aslo using DJI D RTK 2. After the 2 first flights, I had no RTK signal anymore from the base station (even if I moved it). And because I could not take off, I decided to turn it off and did my last 3 flights.
Back to the office, I wanted to process my flights into DJI Terra but only 2 of the 5 folders were recognized. I found that the 3 last flights do not have .RTB file in the 3 folders.
What should I do to process these 3 last flights please?
Does it mean I can do Lidar mission without DJI D RTK 2 base station? All terrains are not flat and sometimes using RTK does not work...
Thank you
Nickthepilot
