JamieE
I've had my OM5 for three days now, and am disheartened to see that using the software causes the iPhone screen to dim to the point of being unusable. It's a visible thing. You can see the screen dim in big steps. What's more is, iOS loses the ability to reset the brightness. Once the phone goes dim, neighter the Control Center brightness adjustment brings it back, nor the Settings brightness slider. You have to power down the phone, and then power it back up. Upon powering back up, you can see the brightness readjust to normal. I've seen post here talking about the app overheating the phone, causing it to go into emergency mode. Thing is, the phone itself isn't getting hot. A little warm, as is normal for prolonged camera use, but nothing major. As for the temperature outside, it is bright and sunny at a whopping 67 degrees fahrenheit.
DJI OM5
DJI Mimo V1.7.14
iPhone 13Pro
iOS 15.4
