dr6583
Flight distance : 490627 ft
GLSpro60 Posted at 3-30 23:45
Apologies, I will re-explain my case. The RC Pro when I first connected it to the Mavic 3 worked with many cuts. Then I linked it again and it worked. So far so good. Then it asked me for the last firmware update and I could never link it to the Mavic 3 again, let alone the Air 2s (I had already done the upgrade). When it connects it gives me a message that there is a firmware inconsistency, it tries to upgrade, and then it says "connect it again after the RC Pro does the reset", but it doesn't do it. I try to reboot the computer but I can't connect to any of the aircraft (neither the Mavic 3 nor the Air 2s. How can I reset the device to an initial factory firmware other than v03.01.0600? Thanks again!
I had the exact same scenario with the A2S initially. It says firmware mismatch, then downloads a small piece of software to the controller, then it says the RCP will restart but never does. Just restart it manually, and possibly the A2S as well. For me, it resolved the issue. |
