WICreekPaddler
Droogles Posted at 4-4 06:44
There needs to be a setting where normal landscape recording can be accomplished in a vertical or horizontal stack configuration. Even smallrig designers don’t get it. Notice how the following cage is marketed in the horizontal stack position: Smallrig Cage 3661
What I'm after has nothing to do with pixels, etc. I want to shoot normally, with the resulting footage being in landscape, with the camera being mounted or held in a horizontal stack configuration.
The sensor is 4:3. If you want record 16:9 while being placed horizontally, the only method is to crop 16:9 from a 4:3 sensor image... which cannot reach a 4K resolution.
If you just want to get a 16:9 video from the camera directly (at most 2.7K) no matter how the action2 is placed, then you can do this...
1. Use HorizonSteady.
2. Swipe down: Select Orientation Lock when placed vertical. Then no matter how you place the camera, vertical/horizontal, you always get a16:9 video.
Orientation lock will need to remain on and locked.
TL;DR - There's no possible way to get full 4K 16:9 video by filming horizontally.
This is information I was given directly from DJI-ytao in the R&D group at DJI. |
