Isaac RC
I second that as I'm having trouble with stabilisation in my current mount setup, 360 and 180 degrees are known to be more solid with stabilisation.
If I may suggest some ideas, 360 degree stitching with dual 180 degree lenses aren't clean as the stitching division is visible in all the actual cameras. Perhaps only a 180 degree lens already would be an upgrade for stabilisation, further more could be adapted in front of the actual lens module without the need to upgrade on a new module with its costly electronics, because as you may know fisheye lenses don't usually go with protection so if it breaks one only should replace the optics itself instead of a whole module.
Well, that or making a 360 module with more than 2 lenses to produce better stitching quality perhaps?
