P.Hansen
Flight distance : 1649491 ft
Denmark
DJI Paladin Posted at 5-8 17:51
Hi there. Thank you for reaching out. As per checking here, it shows that the mobile device that you mentioned is not listed on our compatible mobile devices for the DJI OM 5 and this might be the main cause of the issue that you experienced. We strongly suggest using a compatible device to avoid issues. You may refer to the link below for your reference. Thank you for your valued support.
https://dl.djicdn.com/downloads/DJI_OM_5/DJI_OM_5_Mobile_Phone_Compatibility_List_en_1112.pdf
Er der nogen planer om at opdatere appen så den bliver kompatibel med samsung s22 ultra??? |
