Having read the excellent tutorial for the Mavic Mini Two by No Original Thought a few weeks back, I was inspired to follow up and have a go myself with my Mini One. The DJI Fly App unfortunately does not have this function for the Mini One however, and so I used the Litchi Beta version for my attempts. Sure enough, I achieved some satisfactory results – albeit with the looming Black Hole at the top. On to chapter 2 of N.O.T.’s tutorial regarding the filling in of the black hole. I was less interested in the idea of filling in with a logo, and so he and I have had an exchange of ideas on how to disguise the hole in the sky.
Apparently, the DJI Fly App has a default setting of 26 images in a grid, from which the Panorama is created. The Litchi Beta App has the option to select the number of rows and columns required, and also one or more nadir shots (vertically downwards). I’ve experimented with various options – taking up to 88 shots in total in the expectation that this would give better stitching. Maybe it does, but the number crunching causes the laptop to go into overdrive for a good five minutes.
Again following the ideas of N.O.T. for filling the black hole, I selected an image from the stack which had as much matching sky as I could judge might merge successfully. From this image, I copied and saved a section as TOP.jpg. This had to be resized to the same dimensions as all the other images ( in this case 4000x2250) before incorporating it into the panorama, using Kolor’s Autopano Giga software.
Again continuing as per the instructions of N.O.T. I added the new image to the stack, but here is where the method differs slightly. The added image has to be modified as he explains, but I discovered that you should, before modifying the Pitch and FOV settings, convert it to a seperate layer by right clicking on the image and selecting Move to New Layer from the dropdown menu. Then a double left click on the Pitch and FOV values will allow modification. I agree with N.O.T. that the Pitch value should be 90. But the FOV value can be selected as required to make the extra image fully cover the black hole. I found the a value of between 140 and 150 was required to achieve that. A preview appears in the Edit section so that you can adjust it to your satisfaction. In the dropdown menu for Render, I found that it is handy to set the output width and height to 15000x7500 - the maximum that Skypixel allows. Then it was time to run the program and check the result, which you can see at the link below. Hope this helps someone - and I'm open to other ideas and comments
