Broadcasting FPV Video
766 8 2022-5-12
Certified Aerials
Does anyone know the channel frequencies on the manual broadcast mode ie channel 1, 2, and 3?
Is the transmitted video what the drone camera is recording or just the goggles tx video?
2022-5-12
SgtRay
Flight distance : 14860804 ft
The broadcast transmission if you have your goggles set to auto is chosen by the goggles. It is only the view that the goggles get.
Just make sure that you have your transmission set to broadcast in the menu so that other goggles can find it.
2022-5-13
Certified Aerials
SgtRay Posted at 5-13 00:16
Thanks for the reply!
I'm looking for this exact frequency information so that I can pick up the feed from another device (not DJI) without a spectrum analyzer.
2022-5-13
Yaros1
Flight distance : 19981112 ft
Certified Aerials Posted at 5-13 02:25
It is not possible as far as I'm aware. It is an encrypted signal.
It isn't like Analog FPV video transmission that can just be picked up and displayed by any FPV receiver.
2022-5-16
Certified Aerials
Yaros1 Posted at 5-16 04:34
I believe the RF company I'm working with has that ability to decode the signal I just need the channel frequencies. My initial thoughts are that the goggles feed is not "broadcast quality" and I'll have to put a GoPro on the unit with a small tx. Only issue there is that I lose tilt control and the controls get a bit wonky.
2022-5-16
Yaros1
This might help:
2022-5-16
Certified Aerials
Yaros1 Posted at 5-16 04:57
This might help:
[view_image][Image]
Ohhh yesss!! Where did you find this? Is there similar info for the 2.4 band?
2022-5-16
Yaros1
https://oscarliang.com/fpv-channels/
2022-5-16
Certified Aerials
Yaros1 Posted at 5-16 05:11
Thank you for your help
2022-5-16
