Spark will not connect to RC Flashing yellow lights
1487 4 2022-5-14
BeatNBruised
Flight distance : 472 ft
Hello all.
Just pulled out my spark(been in storage for a whilke) and the drone will not connect. Cycles through lights and then flashes yellow quickly. Does not look to be starting up correctly. Gimbal does not move. RC looks to be connected to my device(pixel 6) but never connects to the drone.(have cable connected)
Drone or RC will not connect to a computer to check or update the firmware. DJI Assistant does not see the devices.(two different computers)
Any tricks to try or ?.
Software works fine. Connects to mavic mini no problem.
2022-5-14
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to uninstall the DJI Assistant 2 software that you are currently using and please install the version below. Update/refresh the firmware of both aircraft and RC then perform the manual linking and check if the issue persists. Please keep us posted. Thank you for your valued support.
https://www.dji.com/downloads/softwares/assistant-dji-2
2022-5-14
BeatNBruised
DJI Paladin Posted at 5-14 23:07
Thank you
Uninstalled and reinstalled on two different computers. Same thing.
Drone turns on, no gimbal activity, looks normal and then the lights go to solid red, and
yellow lights that blink quickly. Used two different cables also.
Software never sees the device.
2022-5-15
BeatNBruised
BeatNBruised Posted at 5-15 06:12
Thank you
Also installed software on a macbook air. Still cannot see the drone, lights flashing quickly, yellow.
Anyway to reset the drone without a computer? to an original firmware?
Or has this drone turned into an expensive paper weight?
Three different computers and the same thing.
Thank you for any input.
2022-5-17
DJI Paladin
Thank you
Please note that the DJI Assistant 2 software that you used for your DJI Mavic Mini is different from the DJI Assistant 2 for the spark. If the issue still persists, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Thank you for your understanding and support.
2022-5-18
