frankymusik
Flight distance : 27904331 ft
Hi KnNLmS,
it is certainly also a question of how often the (micro) SD card actually has to be "exchanged"!!!
At least on the Windows PC you can connect the M3 with a USB-C cable, then switch on the M3...
... and all data can be transferred from the (micro) SD card to the PC.
The data transfer rate for me is about 40 MB/s, so it's pretty fast...
This (micro) SD card can then also be formatted directly from the PC, so that removing the card does not seem necessary at all, in any case not after every flight...
