Geo_Drone
Flight distance : 2676129 ft
Romania
Bashy Posted at 5-17 23:00
Thanks for the details, it all helps, do you really think #3 is a Pro @ 1000m, i know your CE as we are in the UK but 1000m at 80% signal is poor, your looking at it wrong too, if its poor distance wise, its going to be poor close in too when it comes to buildings, trees, giants, etc. meaning you'll lose the signal far sooner than you should. Max transmission for CE should be 8km as stated, but even 3-5km should be doable and if the Mini 2 is anything to go by, the limitation in FCC is only the battery.
I know Bashy, probably will be updates and signal optimized by DJI.
As far as I see now, the RC with screen incorporated is having less signal than RC N1 remote with antennas outside.
Cannot say is from Firmware or is just made wrong with the antennas built inside...we will see.
For inside city if I go a little far, i use Evo 2 Pro as is more heavy and stable, not Mini 3...This will be used as a free time drone, for personal use, as is lighter...
But yes, you are right, the signal in this RC is weaker. |
