I accsidently crashed my mini 2. 1 rotor stoped working than i fixed it and it worked again. I got a massage to update the firmwere and now my drone is stuck updating in a weird way.If i try to instal it again my phone says checking battery could take about 1 minute something like that. What can i do???? i've litearly had it for 1 day
I just dont know what to do downgrading is imposible since it doesnt conect to dji assistant and i had this drone for less than 2 days for my confirmation :,(
Are you trying to update via the Fly App? If so, then try using DJI Assistant 2 software and see if you can even connect to the drone. You can find the DJI Assistant 2 (Consumer Drone Series) V2.1.10 software here.
DowntownRDB Posted at 5-23 10:55
Hello there IzakMaSixpacke. I am sorry for the trouble this has caused and thank you for reaching out. Since there was a crash that happened before with your DJI Mini 2 and now you are having this issue. I would recommend you to contact our DJI support team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We will do there best to evaluate the said DJI drone and will give out the best resolution for this issue. Again, I am sorry for the trouble and thank you.
DowntownRDB Posted at 5-23 12:21
That's not good. Was there any other visible damage from the crash? Could be something wrong jarred loose on the electronics internally.
Probably best if you contact DJI Support.
Well only rotor stoped working for a while then i cleaned it and camera fell down. But mostly just mini scratches
