Sean-bumble-bee
Flight distance : 15997 ft
djiuser_QUiMbzE3lwLX Posted at 5-25 03:18
If my signal is going even at a distance of 500 meters, please do not write 10 KM on the box. I am more sorry than you because I paid my 3rd salary just for this device because of the economic problem my country is in. But you only blame me Have a nice day.
At some point in your, or someone else's, usage of this drone, the response to a disconnection, FAILSAFE, had been changed from the default of RTH to LAND.
So, in the sense that when it suffered a disconnection, it landed, that is your fault, no one else's.
Even if someone else changed the setting you should have checked the setting before flying and especially before lying over water.
Also as JJB pointed out setting the RTH height limit to 500m is, if used, wasteful of power and, for this flight, probably illegal. The height limit in Turkey appears to be 400ft/121m above the ground beneath the drone. It seems you have quite often been above 400ft and in one flight you went up to almost 1000ft over water.
In addition such height may put the drone up into strong winds which may blow your drone away.
As for JJB's ''customer support'', aside from diagnosing the reason for the drone's loss, part of what folks do here is give advice aimed at teaching people to fly their drones more wisely and safely.
There is no point in the likes of JJB lying so as to not offend a pilot, settings and physics have little regard for peoples' sensibilities.
Set inadvisable settings and you are likely to suffer as a consequence, in this case you did.
Maybe, if you get another drone, you will remember theses posts and JJB will not have wasted his time.
