djiuser_peabxhAMqz1c
Flight distance : 96483 ft
Mashroomhut Posted at 5-25 11:24
Hallo, djiuser_peabxhAMqz1c!
Is the aircraft in the air during the preview/overheating? Mini has no active cooling system. It must be in the air to cool the electronic components and transfering video from the aircraft to the controller could produce some heat.
If it is the case, my advice for you would be to do it when Mini is in the air, or plug the SD card to your mobile to see the records.
The aircraft is not in the air. You are right that this is possibly just a feature of the device. Thank you for your advice! I will preview footage when the aircraft is in the air in the future. Thank you! |
