trouble calibrating the compass on my Mavic Air 2
397 6 2022-6-4
Gio3D
Brazil
I'm having trouble calibrating the compass on my Mavic Air 2.
It just doesn't calibrate. Could it be the magnetized camera? Because I already had the problem with my Mavic Pro with this.
I'm waiting for a response because I'm waiting to work with the drone.
2022-6-4
DJI Gamora
Hi, there. Sorry to hear about this. It is recommended that you calibrate again in another environment. If the calibration still fails, please give us a video showing how you calibrate the drone and the error message. Thank you.
2022-6-4
Gio3D
Brazil
I'll try again.
Could it be something from magnetism?
On my Mavic Pro I had this problem. what do you think?
2022-6-7
Gio3D
Brazil
I also have a battery that didn't turn off all the lights when charging for the first time.
I charged directly on the charger, I did not use the auxiliary that charges the 3 at the same time. 1 battery had very different cells.
2022-6-7
DJI Wanda
Gio3D Posted at 6-7 07:06
I charged directly on the charger, I did not use the auxiliary that charges the 3 at the same time. 1 battery had very different cells.[view_image]
Hello, there. Thanks for your reply. May we know have you tested calibration at another place without signal interference? For your battery, we would recommend you change the battery.
2022-6-8
Gio3D
Brazil
I did the calibration in several different places.
2022-6-10
DJI Wanda
Gio3D Posted at 6-10 11:09
Hello, there. If the issue persists after you change to a different environment, we would recommend you apply for an online repair request and then send it back. Here is the link: https://repair.dji.com/repair/index
2022-6-11
