RTH In M Mode?
708 2 2022-6-5
djiuser_U3aIgxtVwsLC
Hello,
I have seen posts in which people have stated the RTH button does not work in Manual mode, but what if you loose signal in Manual mode, does RTH not work then? If not, does it just plummet to the ground?
Thanks
2022-6-5
RH009
Flight distance : 2234616 ft
Once it loses signal, it should brake and return to N Mode and RTH according to how you have RTH setup in it.
2022-6-5
DJI Stephen
Hello there. Good day and thank you for reaching out. Kindly please refer to the post given above by RH009 on post #2 with regards to this matter. Thank you.
2022-6-5
