loic2665
Flight distance : 1636542 ft
Labroides Posted at 6-15 03:37
leaving the front untouched to let the gps doing it's job correctly, even if it a layer of plastic
Save your caution for things that actually matter.
GPS signals won't go through rock, concrete, water or metal, but your sticker is completely transparent to the radio signal (unless it's metallic).
Hi, the registration of my drone does matter, I want to be a responsible pilot and fly my drone with no problem, putting it on the top makes it easier to read information related to it, but I wanted to be sure, because with the previous firmware the GPS has a slow fix, I didn't wanted to add another layer of material no matter what the type is.
I came from a Phantom 3 Standard that has only GPS and not GPS-A technology in it, so I always had 9-10 GPS satellites locked-in and it worked fine but I had more risk or having a locking issue, but when you have GPS-A with 23 locked-in satellites that's better, but I prefer to avoid any risk. :-) |
