Burt37
Flight distance : 4009 ft
DJI Stephen Posted at 2022-6-14 19:32
Hello there Mini3Valencia. Thank you for reaching out and for posting these information. Just a friendly reminder that the DJI Mavic 3 Pro does not have a fan, so it uses the heat sink on the bottom of the DJI drone to dissipate heat. After the DJI Mini 3 Pro is powered on and kept on a flat surface ( such as ground or a desk ) for a while, the heat dissipation will be affected, as the surface is close to the heat sink. In this case, the DJI drone should be turned off and kept idle for a while to drop its temperature before using it again. In addition I hope that our fellow DJI co pilots who owns the DJI Mini 3 Pro can share there valued insights with regards to this matter. Thank you.
Not to be pedantic but there are no heat sinks on the bottom of the Mini 3 pro... All the heat generated it is normally felt on the side and the top...
The battery also seems to get extremely hot to the touch, when not flying...
Only valid solution so far and suggested by most, is to have a little fan blowing on the drone while it is on and not flying. When it flies the rear blade are blowing air inside the unit from the top (where the heatsinks presumably are, as heat always rises) and keep the unit at a more decent working temperature...
