Camera meandering.
956 9 2022-6-19
djiuser_wEEMwZQqm66F
Flight distance : 243885 ft
The camera does not follow the horizon when rotating, it angles, then settles back to level when the motion stops. Same while looking straight down, it meanders, then slowly corrects itself. Gimbal calibration completed. IMU calibration completed. Latest versions of software installed.
2022-6-19
fansb1fe1104
Flight distance : 3372566 ft
I've had that same problem for years. As far as I know, there is no fix for it.
2022-6-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to download the DJI Assistant 2 software and kindly please update/refresh the firmware to see if the issue persists? In addition, could you please send us a sample video showing the issue for us to check? Please keep us posted. Thank you.
2022-6-19
JetSam
Flight distance : 3462946 ft
fansb1fe1104 Posted at 6-19 14:37
same here ...... Horizon tilts and go so slow to get the normal position ......
2022-6-19
JetSam
i tried everything ... Actually the Main camera Board and rear ESC ,..... are Broken ....
2022-6-19
JetSam
It is a serial failure of some of our devices, which Dji never wanted to recognize..... thousands of users affected by this problem, without their device having suffered an accident.
2022-6-19
Survey Guy
DJI Paladin Posted at 6-19 17:46
I have tried to upload video....unable.
2022-6-20
Alicatt
Flight distance : 10971 ft
Belgium
Having the same problem with mine, camera is so slow to return to the horizontal and now cannot recalibrate the sensors
2022-6-27
Survey Guy
I have done all the updates, used DJI Assistant, updated firmware and still unsatisfactory.
I can't seem to upload a video to share.
2022-6-28
DJI Paladin
Survey Guy Posted at 6-28 19:11
Thank you for keeping us posted. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Thank you for your kind and understanding.
2022-7-15
