Signal Problem _ PLEASE DJI READ HERE
1735 13 2022-6-20
Raf_IZ0QWM
Flight distance : 1640843 ft
In these two videos we talk about a problem found by Gavin HR in the band switching
We are doing a survey on many users and it seems that some models of DJI MINI 3 do not correctly switch the band in case of disturbances or even never do it and remain on the 2.4GHz frequency.
This problem could explains why some drones complain of a bad range especially in urbanized areas and others do not present any problems.
2022-6-20
Andre vd Weide
Flight distance : 1503937 ft
maybe its an option which frequency to see on the display so every one can see what is used
2022-6-20
Raf_IZ0QWM
Andre vd Weide Posted at 6-20 04:07
Yes, great, could be really useful when you record the display during a fly or you simply use the drone and permit to check frequency band used.
2022-6-20
DJI Stephen
Hello there Raf_IZ0QWM. Thank you for reaching out and for posting this video here at DJI Forum. I will forward this post to the designated DJI department for attention. Thank you.
2022-6-20
Raf_IZ0QWM
DJI Stephen Posted at 6-20 18:53
A thousand thanks!
I appreciate that you replied to the post. Available for further clarification
2022-6-20
DAFlys
I set mine manually to 2.4ghz and did a test and got no better range or connection than leaving it on auto.
2022-6-20
djiuser_Fjm5pOHeyXKJ
Flight distance : 181266 ft
Sweden
DAFlys Posted at 6-20 23:29
It has zero effect on mine too.
2022-6-20
DAFlys
djiuser_Fjm5pOHeyXKJ Posted at 6-20 23:32
For me the video feed was actually smoother when setting it to auto on the same route.
2022-6-20
OffRoadDave
Flight distance : 64514 ft
Brilliant Idea.
2022-6-21
DJI Stephen
Raf_IZ0QWM Posted at 6-20 22:05
A thousand thanks!
Hi there Raf_IZ0QWM. You are very much welcome and thank you for the reply. Have a safe and a happy flying always. .
2022-6-22
Montfrooij
Flight distance : 2560453 ft
I hope they can find a fix.
2022-6-24
Raf_IZ0QWM
DJI Stephen Posted at 6-22 21:46
Thank you very much. I have just seen the new update and this:
Optimized the anti-interference ability and the transmission distance of the image transmission system.
Great Stephen to you and your colleagues
2022-6-30
mkdp.photos
Flight distance : 717218 ft
Raf_IZ0QWM Posted at 6-30 10:40
Apparently it did not change much though
2022-6-30
DJI Stephen
Hi there Raf_IZ0QWM. Thank  you for the reply and for sharing your positive feedback for the new DJI update. Again, thank you for your support and have a nice weekend. .
2022-7-1
