Horizon level issue during pan/rotate
594 3 2022-6-20
Mgozer
Switzerland
Hi
I've been using Mavic Pro for several years now, but I cannot stand anymore the horizon issue it has.
When panning or rotating the drone (or both  at the same time), the horizon gets a little tilted to the right or to the left.
Is there any solution to this issue?
Thanks a lot.
2022-6-20
Blériot53
Flight distance : 6188465 ft
I had a Mavic Pro Platinum for a couple of years, and noticed this problem from time to time - generally on the windier days. Never did get to the bottom of it, even after several recalibrations of the gimbal.
2022-6-20
DJI Stephen
Hello there Mgozer. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to calibrate the gimbal of your DJI Mavic Pro to see if the issue will persist and may we please know if you are receiving any error message or error code on the DJI Go 4 application when this is happening? Thank you.
2022-6-20
Mgozer
Switzerland
I already tried to recalibrate the IMU, the compass and the gimbal, but no success.
This is an issue I have, an almost anyone have, since I got the Mavic Pro (2017) and hoped it was solved anyhow...
Too bad
2022-6-20
