Straight iPhone controller cable?
937 4 2022-6-23
djiuser_aVjM3FPerQY3
Hello, looking for a solution to connect my iPhone with a case to the controller for an air 2s.  I’m having a hard time finding certified cables without 90 angles. I don’t mind the 90 plug on the controller but need a straight plug on the iPhone/iPad lighting side. Does anyone have any links or solutions. Regards
2022-6-23
DJI Stephen
Hello there. Good day and thank you for reaching out. You may try check our DJI Where To Buy platform on this link ( https://www.dji.com/where-to-buy ) to see if those cables that you need is available. In addition I hope that you can get some recommendations from our DJI Co pilots with regards to this inquiry as well. Thank you.
2022-6-23
fateofangel
Flight distance : 1397238 ft
Poland
Can you explain why you need  straight plug dude?
2022-7-12
fateofangel Posted at 7-12 09:54
Because most 90 degree cables will not fit through my otter box case. I’ve found a VCUTech solution that will work. Regards
2022-7-12
fateofangel
Poland
ah okay, good to hear than
2022-7-12
