SPLflyer
Flight distance : 144829 ft
Bussty Posted at 7-28 21:21
There have been many requests for DJI to change the Pano Sphere Mode to allow Vertical mode and automatically take all required images for a true 360 x 180.
For the time being if using something like PTGUI to stitch your 360 x 180 Panos it will allow you to combine manual vertical shots to cover your Zenith portion with the auto sphere shots to create a perfect 360 x 180 pano. It's just not all automatic :-(
Hi Bussty,
I think the method with a complete sphere will only work if the entire shooting regime is changed to vertical mode – with all the problems that entails. The previous method of shooting three rows in landscape mode and turning the camera on 'vertical' for the fourth shot at each pan to 60 degrees will not work. I guess the problem for DJI is that four rows in landscape mode still leaves a small hole at zenith. That's messy and not DJI-perfect.
However, your method of shooting the fourth row manually in vertical mode leaves the horizontal overlap difficult because of the narrow width of the shots. Add to that the jumpiness of the compass, and creating a gapless fourth row is very difficult.
But why don't you shoot the fourth row in landscape mode as well? Because the images are much wider, a much greater tolerance in the compass jumps is possible. The following shot I took as a first try on an unattractive field. After completing the 'normal' sphere, the fourth row was done manually, horizontally and with estimated compass distances. Then I imported the original DNGs quick and dirty with the original names (7 pieces DJI_0001.DNG - DJI_0007.DNG + 26 pieces PANO0001.DNG - PANO0026.DNG) into PanoramaStudio 3 Pro. After 'aligning', you can clearly see that even large jumps between shots in the top row are sufficient for complete coverage.
The unfilled narrow border at the top can then be easily filled in PS CC 2018 or in Affinity Photo:
This way seems much easier to me manually than using the vertical camera perspective to fill the zenith. |
