Android - how to get callbacks from hardware buttons when pressed
993 3 2022-6-27
djiuser_b9fA0wj643ey
I'm working on a camera app using Android Camera2 SDK which has button for start/stop recording, and a zoom functionality. I've integrated the DJI mobile SDK and I did the registration with the API key generated from the developer account. When I start the app, I receive a `REGISTRATION_SUCCESS` from `DJISDKManager.SDKManagerCallback()#onRegister()` and the Gimbal is connected through Bluetooth to the phone. I test the connectivity with handHeld.isConnected() which returns true.
Now the issue is, how can I intercept the hardware button press events from the Gimbal ?
I tried something like this, but it doesn't work. I couldn't find any documentation about how to receive callbacks when hardware buttons are pressed.
    HandHeld handHeld = (HandHeld) DJISDKManager.getInstance().getProduct();
        handHeld.getHandHeldController().setHardwareStateCallback(hardwareState -> {
            switch (hardwareState.getRecordAndShutterButtons()) {
                case IDLE: {
                    Log.e(TAG, "getRecordAndShutterButtons IDLE");
                    break;
                case RECORD_CLICK: {
                    Log.e(TAG, "getRecordAndShutterButtons RECORD_CLICK");
                    break;
                case SHUTTER_CLICK: {
                    Log.e(TAG, "getRecordAndShutterButtons SHUTTER_CLICK");
                    break;
                case SHUTTER_LONG_CLICK: {
                    Log.e(TAG, "getRecordAndShutterButtons SHUTTER_LONG_CLICK");
                    break;
                default: {
                    Log.e(TAG, "getRecordAndShutterButtons UNKNOWN");
            switch (hardwareState.getZoomState()) {
                case IDLE: {
                    Log.e(TAG, "getZoomState IDLE");
                    break;
                case ZOOM_IN: {
                    Log.e(TAG, "getZoomState ZOOM_IN");
                    break;
                case ZOOM_OUT: {
                    Log.e(TAG, "getZoomState ZOOM_OUT");
                    break;
                default: {
                    Log.e(TAG, "getTriggerButton UNKNOWN");
I tested hardwareState.getStickVerticalDirection() and hardwareState.getStickHorizontalDirection(), by moving the joystick analog and I get approximately the correct values (left/right/up/down)
but all other functions like hardwareState.getZoomState() or hardwareState.getRecordAndShutterButtons() they always return IDLE state. (when I press the record button, for some reason it increases the audio of the phone, and the volume seek bar appears, its like Im pressing the volume button)
These are some logs from handHeld.getHandHeldController().setHardwareStateCallback() that I receive randomly without pressing any button:
/com.dji.sdk.sample E/Camera2: getRecordAndShutterButtons IDLE
Camera2: getZoomState IDLE
Camera2: getTriggerButton IDLE
Camera2: getModeButton IDLE
The model name is: OM5-602S46
Im using the Sample code app to test these hardware buttons callbacks.
It would be great that someone could help me on this.
2022-6-27
DAFlys
Hi! You might be better off posting your question in the 'Developer' section of this forum.  That is way more active.    -   From https://developer.dji.com you can click Forum to access it or a direct link to it is - https://forum.dji.com/forum-139-1.html?from=developer
2022-6-27
Ok, thank you!
2022-6-27
DJI Stephen
Hello there. Good day and thank you for giving out these information. For us to be able to assist you further with regards to this matter, please contact our DJI Development team at the link provided above by DAFlys on post #2. Thank you.
2022-6-28
