Goggles Pisano
Flight distance : 8810745 ft
danyrr Posted at 7-9 22:58
Hi Stephen, I have already solved the problem. Today I got a message to calibrate the DJI RC. After calibrating the controller now the dot turns green right when I point at the drone. The problem that I continue to have, like other users, is that the point sometimes does not appear and reappears without knowing why.
My blue dot disappears all the time too. I found if after every flight if you turn on wifi before you shut controller it helps with next flight. Got mine to work 80% of the time. Sometimes I have to restart controller if it doesn't show up. |
