Vertical mode - Horizon not leveled
1952 13 2022-7-10
Ravelposh
Argentina
Hi all. I'm having kind of a problem with my just purchased Mini 3 Pro. Horizontal mode is fine, looks great, but when I switch to vertical mode, the image is not leveled. Did anyone have this issue?
Here is an image example:
And here you can see how horizontal looks good:
Horizontal
Horizontal
Since horizontal looks good, when I calibrate the gimbal, it doesn't fix the vertical mode. Also when I fixed it manually, the horizontal mode gets unleveled. I couldn't find separate settings for each one, which would solve the issue.
So I'm hoping it can be fixed somehow. Or worst case scenario I might have to return the drone. It's brand new and only flew few times without any issues. Also no crashes or anything out of the normal.
Here is a video when I switch between horizontal and vertical mode. I only press the button to switch, nothing else. It feels a bit weird to see that extra movement every time I do it:
Thanks in advance!
2022-7-10
DJI Stephen
Hello there Ravelposh. I am sorry for the trouble this has caused and thank you for reaching out. Since you have done several troubleshooting steps to fix the issue and still the issue persist. I would recommend for you to contact our DJI support team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We will do our best to help and will give out the best resolution for this issue. Again, I am sorry and thank you.
2022-7-10
PAROINA
Flight distance : 3279160 ft
I have the exact same issue. It is not very obvious when flying (but it is there if you look), but when you lay it flat like this, you see it happening. Just waiting to see if any future firmware updates fixes since they seem to come pretty often. I don't really use the vertical option so it does not bug me at the moment. Would be curious to know if others have the same issue.
2022-7-11
Ravelposh
Argentina
Finally I sent my drone back and they give me a new one. So it was some issue with it, not something common. The new one works perfectly!
2022-7-13
Ravelposh
Argentina
2022-7-13
PAROINA
Ravelposh Posted at 7-13 13:27
Did DJI just say to send it to them and they replaced it because of a known issue or was it covered under DJI Care Refresh?
2022-7-13
Ravelposh
Argentina
PAROINA Posted at 7-13 19:21
No, it was in a local store. I had 30 days to try it out and if something failed I could get a new one or the money back. They didn't tell me if it was a known issue or anything.
2022-7-14
Montfrooij
Flight distance : 2560453 ft
I hope you get it fixed.
2022-8-9
HarleyFlyer
Flight distance : 1356178 ft
Mine does exactly the same - maybe I will see if it can be exchanged in store for me too
2022-8-10
PAROINA
Ravelposh Posted at 7-14 09:04
Finally decided to send mine in to DJI. They state there was an issue with the gimbal yaw axis arm & yaw axis motor module. I have the DJI Care Refresh but they are covering this under the normal 90 day warranty. No costs to me. Just down time since I had to ship it off.
2022-8-15
Bashy
Flight distance : 2354357 ft
You will get that movement, its no different to a normal camera lens in auto on a tripod, it moves, this is why you shut down auto focus when on a tripod, try this test again in manual, cause effectively, the gimbal is the tripod.
2022-8-15
Ravelposh
Bashy Posted at 8-15 19:13
I can guarantee you that the replacement drone I got doesn't do any weird movements. I know the gimbal is not rock solid. However, the new drone doesn't move at all, it switches horizontal/vertical perfectly. The main issue was that it wasn't leveled though.
2022-8-16
Bashy
Ravelposh Posted at 8-16 01:13
Thats interesting cause if you turn on the drone but not the props, and turn it just a little, the gimbal turns to try to compensate for that movement
2022-8-16
Ravelposh
Bashy Posted at 8-16 03:41
Yeah, that behaviour is expected. But it took way longer than expected to do that compensation and in a flat surface without any movement. Just switching between vertical/horizontal mode.
2022-8-16
