FabioV
Flight distance : 980066 ft
fans077b455c Posted at 7-23 02:46
I have found that by fitting a filter to the gimbal and doing an IMU and compass calibration before each flight I can reduce the jello effect to about 20% of the recordings. I also do a gimbal calibration, but this is not working correctly as it will only go as far as 80% before coming stuck - unable to do the final yaw to the right to return to its home position. I have left the calibration running for up to 5 minutes without it progressing beyond 80%. The only way I can resolve this is to gently nudge the gimbal towards the right. The app then gives the expected calibration complete message.
The gimbal calibration task usually takes few seconds to complete. If it does not complete or if it takes much more, it probably means that there is some block or brake inside the mechanism and that the gimbal must be repaired. This can also explain the jello effect you're experiencing: when the gimbal is not completely free to operate as expected, the vibrations from the propellers are propagated to the camera and may impact on the quality of the video.
Before buying the Mini 2, I used to fly with a self made drone. I fought against the jello effects for months, before obtaining somewhat acceptable results ... With the Mini 2 the videos must be jello free out the box also without the ND filters. Then my suggestion is: do not waste time in the forum. Nobody will solve your issue here. You have a brand new Mini 2, then open a support ticket and send it back for a repair under warranty.
