makla
Flight distance : 152382 ft
I just had that very same experience on my very first flight with the Mini 3 Pro ... Lifted off, everything normal, flew around for like 5-10 minutes, took some videos , switched to taking some photos and then:
- Screen turned greyish and image froze
- for approx. 30s I could still send control signals that the drone realised
- After these 30s the drone did some random stuff that resulted in Return Home... well.... almost home... it rather resulted in "hovering right over a tree due to obstacle avoidance"
- I had to span a blanket and wait for a random amount of time (approx 20 minutes) until the battery was fully drained and the Mini 3 Pro crashed (fortunately into my blanket)
During these 20 Minutens I tried everything from restarting everything, reconnecting / pairing and even tried to call customer support (yes, out of office hours). By no means the remote was able to establish ANY kind of connection again after the initial loss of control. During these dreadful 20 minutes I was only 10m away from the drone (vertically, of course ...)
This really is a ... first experience with a new "better" model I flew the Mini 1 for 2 years now, with not a single problem ever and now this bad stuff on the very first flight.
Did you get any further information by now? :/
EDIT: I did check the flight-log and I found, that at the time where the problem started, the log shows a warning 'GPS signal weak. Switeched to Attitude mode. Aircraft unable to hover. Fly with caution' , despite of having lock on 30 satellites. I do see NO reason for that as weather was very good, the area is extremely open (above fields). I attached a screenshot of this particular log-part.
