oldpeach
New bird arrived today, with a B controller and ver 119 installed. The DJI GO app connected no prob
Performed update the instructed way with errors but recovered and installed
Used micro 2 gig micro sd card and as per instructions copied all files from the zip to the root
Started the bird , it chirped and beeped four times then started making steady hum noise..
After 15 mins I noted the gimbal light was solid red and NO 4 beep pattern
I turned off the battery to check and the update file said failed
I then took the sd card that came with the bird and took all files and folders off of the card
Then placed just the bin file (not all files that were in the zip as per instructions)
Placed in the bird and started again
4 beeps and flashing lights, at one point all lights went out and the gimbal went nuts
But the whole time the gimbal light flashed red then green
Update successful
The controller was different and I used a sd to usb converter and also tried plain usb ... No go
Then I connected the GO ap and followed the download software menu.
It downloaded in few minutes and I initiated the upgrade
Finished in minutes with success
Being an I.T. Guy,, I'm well aware of usb drive in compatibility so id suggest to others to have a few good brand name sticks to try
50 minutes to complete everything
