FantomDK
Denmark
I hate to correct your video... but I'm gonna do it any way
You made a few inaccurate statements. One that was pretty glaring was the mentioning of 40mbps vs 60mbps video. You mentioned this had something to do with the live video feed. It does not. It has to do with the bitrate of the recorded video (ie. the compression). 60mbps h264 (30fps) for the P3 4KPro isn't bad - but it is still fairly heavily compressed. 40mbps is obviously a lower bitrate (smaller files by the way too) but since it is a 2,7k or 1080P resolution, it isn't bad at all.
Also, you were a bit unclear with regards to the resolutions. Easier to just look up the spec-sheet on the DJI-website - but 2.7 is 2704x1520 and 1080p is 1920x1080. Also, it is significant, that the Phantom 3 Advanced does 1080p60 frames per second where the P3Standard only does 30 fps (or 720p60).
In my opinion the DJI Phantom 3 Standard is more of a Phantom 2,5 - a mix between the P2Vision+ (same remote, no lightbridge etc.) and the P3 (Inspire-ish remote, Lightbridge, Glonas). |
