Motors specs, weight and KV
7854 3 2022-8-7
cold_dog
Flight distance : 343520 ft
Russia
Does anybody know the technical specs of the motors on mini 3 pro? Weight and KV rating.
2022-8-7
CloudVisual
Flight distance : 97545420 ft
Model of Motor: 1504C
Type of Motor: Brushless
Diameter: 18 mm
KV: 2824 rpm/V
Rotation Speed While Hovering (Rated Operating Voltage): 6040 rpm
Maximum Rotation Speed (Rated Operating Voltage): 10700 rpm
Rated Output Power of One Single Motor: 3.71 W
Maximum Output Power of One Single Motor: 22.3 W
Rated Operating Voltage of One Single Motor: 7.4 V
Distance between the installation positions of two screws on a motor: Approx. 1 cm
2022-8-7
DJI Stephen
Hello there cold_dog. Good day and thank you for reaching out. Kindly please refer to the post given above by CloudVisual. In addition I will post a DJI Link where in you can find the Frequently Asked Questions and Specifications for the DJI Mini 3 Pro. Thank you.
https://www.dji.com/support/prod ... ndsite&from=nav
2022-8-7
djiuser_yx6Y2rB9bBL6
Indonesia
CloudVisual Posted at 2022-8-7 05:37
Diameter: 18 mm
weight of the motor?
5-12 21:02
