juan55
Flight distance : 577096 ft
https://forum.dji.com/forum.php?mod=viewthread&tid=265161
AEB bracketing of 0.7 EV is uses less in photography…. Only option is shoot in PRO (Manual) and adjust Shutter speed to have the + - EV you need, shooting 3 or as much frames you need. Afterwards you blend them in post processing.
As this drone has a fixed diaphragm of f/1.7 … you can only play with the Shutter speed (must convenience) and the ISO to change the EV. The EV display showed in the screen in PRO mode is like the meter needle of the old manual cameras. Shows you how much far you are (in one side or other) from the perfect exposure.
For that, it helps to config the DIAL+ Custom Button, one for changing shutter speed and the other to change the ISO
