Dji Fly not Compatible with Poco F4 GT
3799 27 2022-8-10
fans902160db
Indonesia
Just bought new phone, but seems it have problem just from the start. Open white screen, try to rotate, and closes. Same problem with other DJI app. Fortunately I have Litchi for backup (opening fine)
2022-8-10
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to uninstall an reinstall the DJI Fly application ( https://www.dji.com/dji-fly ) to see if the issue will still persist? In addition, please sync all of your flight records before uninstalling the DJI Fly application on your mobile device for you not to loose your previous flight information. If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
2022-8-10
fans902160db
Indonesia
I've done install/uninstall multiple times. Still not working. My previous device (Oneplus 5) can run it without problems. But after transferring to new device, I wipe clean my old device. I have the same problem with DJI mimo software. Other external app (non play store) can run without problem in my new device.
I don't know where the compatibility issu lies. Maybe in Android 12, or New processor type?
2022-8-11
DJI Stephen
fans902160db Posted at 8-11 17:23
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. We have sent you a PM, kindly please check. Thank you.
2022-8-11
fans902160db
Indonesia
deleted. PM not seen in mobile mode.
The version in PM sent works for me. Do you have similar solution for DJI Mimo?
2022-8-12
djiuser_aNOtZtaZQs70
Colombia
I'm having the same issue, did you find any solution?
2022-8-23
fans902160db
Indonesia
DJI Stephen send a link of working version for me. I don't know if I can share it here or not.
2022-8-23
djiuser_wVBovrST3lOb
Flight distance : 17277 ft
Georgia
I'm having same issue with dji go 4 on Poco f4 gt, app closes once I open it, please help
2022-8-28
Georgia
DJI Stephen Posted at 8-11 21:24
Hi, can you help me? Im having same issue with dji go 4 on poco f4 gt, app closes once I open it
2022-8-28
fans902160db
Indonesia
djiuser_wVBovrST3lOb Posted at 8-28 07:09
Check your PM (using desktop mode or PC)
2022-8-29
UncleSam40
Flight distance : 75673 ft
I also have problems, can you send me dji go 4 for poco f4gt
2022-10-23
UncleSam40
Can you send me also the App who ist working
2022-10-25
DJI Stephen
UncleSam40 Posted at 10-25 10:46
Hi there UncleSam40. Thank you for reaching out and for these information. After reading your reply above I understand that you are having issues with the DJI Go 4 application. Kindly please try to install the DJI Go 4 application from this DJI Link ( https://www.dji.com/downloads/djiapp/dji-go-4 ) to see if the issue will still persist? If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the issue. Thank you.
2022-10-25
UncleSam40
DJI Stephen Posted at 10-25 19:27
[view_image]
thank you for your answer i have done it to install the new one what is not infunction.
to weeks ago i was able to fly with the DJ i go for
2022-10-26
DJI Stephen
UncleSam40 Posted at 10-26 19:02
Hi there UncleSam40. Thank you for the reply and for these additional information. May we also please know what is the model of the mobile device that you are using please for us to be able to isolate the issue? Thank you.
2022-10-26
djiuser_UziKv9kSpA42
Indonesia
fans902160db Posted at 2022-8-23 14:06
Hi mate can you send me the link DJI fly app that work for Poco f4. I got same problem, previously running it on oppo Reno 2f it work fine. I have change my phone to poco f4 turnout to have same problem with you.
2023-1-13
fans902160db
Indonesia
I am currently using latest version and working fine.
2023-1-13
Indonesia
fans902160db Posted at 1-13 18:15
On your Poco f4 phone?
2023-1-19
fans902160db
Sweden
djiuser_UziKv9kSpA42 Posted at 1-19 15:53
Poco F4 GT to be specific.
2023-1-19
djiuser_b1jHSeEEl1wN
Mexico
Hello, I can't use the drone (dji mini 2 se) it seems to me that the device is not compatible, I already installed and uninstalled the app several times and I still have the same problem, my cell phone is the Poco x4 Gt
2023-5-19
DJI Tony
djiuser_b1jHSeEEl1wN Posted at 5-19 10:54
Hi there. Thanks for reaching out, and apologies for the inconvenience. For better understanding, can you please elaborate more on the specific issue you're experiencing? What errors are you getting? Are you able to link the drone to the remote controller? We will  be waiting for the additional details. Thank you.
2023-5-20
Dji stephen , can u send me the same link please , i too have the poco x4 gt
2023-5-24
Mexico
DJI Tony Posted at 5-20 03:12
When I turn on the drone and then connect the cell phone to the control, it automatically appears (non-compatible device)
2023-5-27
Mexico
djiuser_b1jHSeEEl1wN Posted at 5-27 04:44
When I turn on the drone and then connect the cell phone to the control, it automatically appears (non-compatible device)[Image]
It looks better in this image, what appears to me
2023-5-27
DJI Tony
djiuser_b1jHSeEEl1wN Posted at 5-27 04:45
Thanks for the update. When you said you have tried uninstalling and reinstalling it, did you install it from the DJI website?
2023-5-27
Mexico
DJI Tony Posted at 5-27 07:37
Yes but it still shows the same
2023-5-27
DJI Tony
djiuser_b1jHSeEEl1wN Posted at 5-27 08:43
We understand. We'll be sending you a PM to gather more details for an analysis. Please check your inbox.
2023-5-28
NADS60700
Flight distance : 350965 ft
It didn't work last year with Poco F4GT.
With the DJI Fly V 1.11.0 it works fine now (2023/07/30).
You can download it here https://www.dji.com/fr/downloads/djiapp/dji-fly
2023-7-30
