DJI Thor
Flight distance : 13602 ft
Hi, there. May we know the setting of your Obstacles Avoidance Actions? Please note that if Bypass is selected, the aircraft will not fly right or left to influence the stick movement. However, this will not affect the aircraft’s automatic obstacle avoidance. For example, if there is an obstacle ahead, the aircraft will automatically fly to the right or left to avoid obstacles when you move the stick. Besides, please try to perform flights in different open-air areas to see if the lost signal issue persists. You may also try to refresh the firmware of the battery and the drone to the latest version. |
