Sean-bumble-bee
Flight distance : 15997 ft
To be honest buy and swap testing can work out to be expensive, if the second board does not solve the problem I would be inclined to send the drone in for repair.
Just a point, if your ebay has the same T&C as here in the UK and if your first seller sold the board in the "USED " condition category then the item must work.
If it doesn't then a "not as described" return can be initiated whereby the item can be returned, at the seller's expense, and, on reciept by the seller, a full refund issued to the buyer INCLUDING the original P&P charge.
Here the seller can send a prepaid postage label.
With regards to a board to which soldered connections must be made, that is probably a bit generous as the buyer could be a hamfisted numpty and damage the board but ........
For this reason most sellers here sell such parts in the "FOR PARTS" category where the "must work "condition is not applicable. |
