Bashy
Flight distance : 2354357 ft
Labroides Posted at 8-11 19:32
DJI says, the best distance travelled is at 21.6kph
They don't, they say that longest flight time is achieved at that speed..
Here's where you got that speed from:
OK, my wording was off a little, i was paraphrasing.
Yes, they do, they say "measured while flying". Unless that means something else?
What else can "34 mins while flying at 21.6kph" mean?
DJI says the longest running time for the battery is at 21.6kph.
You say the longest running time for the battery is at 36kph, this would give the greater distance for sure.
You can understand my confusion here, so why doesn't DJI say that 36kph is better for the longest running time, not to mention it would give you the greater distance too if the range doesn't cut out 1st.
Because DJI don't specify max distance per battery anywhere.
Oh, what does this mean?
- Max Flight Distance
- 18 km (with Intelligent Flight Battery and measured while flying at 43.2 kph in windless conditions)
But then that sort of supports your Normal mode to an extent, although DJI are saying its actually faster.
So now i am really confused, In one breath they say the longest running time for the 34 min battery is at 21.6kph, but then they go on to say that the max flight distance (transmission) is accomplished at 43.2kph
I am not being argumentative, i just don't get it...
As for the fuel economy analogy, its not great, the manufacturer specs are based on 56mph, this isn't a ''cut in stone'' figure, it varies from car to car but its a figure that they came to as a catch all, not to mention it was a figure that they came up with many, many years ago when they tested the 3 different speeds. Typically it varies now from 45mph to 50mph. If i was to drive my volvo on cruise control at 30mph, i get about 85mpg, at 40mph, i can get around 70mpg, at 56mph, i get around 55mpg and at 65 I am lucky to get 40mpg. If you're on a flat road, the slower the speed, the less fuel you use, this is obviously offset by hills etc so its going to hurt the MPG at the slower speeds, this is why 56mpg was deemed optimum back in the day, its also not too slow as to slow traffic down, could you imagined all the old timers driving everywhere at 40mph because someone said that that was the best for fuel economy. Certainly for my car, the slower the speed the more MPG i can get.
