dji.huras
Hey folks, newcomer here, but have been having fun flying my Phantom 2 for many months.
Recently, I had a crash. I think it was due to a battery problem. Battery showed at full
charge (4 lights) before take off. I took off, and was hovering at a bout 5 feet for about
1 minute, while deciding on my flight route. Then the lights changed from flashing green to
flashing red. I could no longer control the Phantom. Within a few seconds, the props stopped, and
the Phantom simply crashed straight down. Luckily no permanent damage. Gimbal was bent, but that was
fixable. I do not believe I completely lost power, as the Gimbal was still running, and the unit was humming.
But the props were stopped. When I checked the battery, it was now down to only
2 lights ! (Yes, it went from 4 to 2, in a matter of about 2 minutes).
So, I tentatively concluded something was wrong with the battery.
Bent the gimbal back into shape, and tried another battery. Full normal flight.
So, some questions :
- has anyone else experienced anything like this ?
- how does one check for battery health ? is there good way to do this, to prevent
such crashes (I was lucky I was only 5' above the ground when this occurred - if I
was higher, and/or a distance away, this could have easily caused permanent damage
or worse, hurt someone)
- what is the best strategy for ongoing battery maintenence
Thanks in advance,
