Lecep
Flight distance : 251115 ft
DJI Paladin Posted at 8-17 18:38
Hi there. Thank you for reaching out and we're deeply sorry for the trouble. Can you please try to download the DJI Assistant 2 software and kindly please perform the vision sensor calibration and have a test flight then check if there are some changes? In addition, kindly please try to fly to a different location and check if the issue persists. Kindly please download the DJI Assistant 2 version below. Please keep us posted. Thank you.
As suggested, I ran the calibration process and tested it again. This time I tried around noon, when the sun is at the highest, as opposed to yesterday that was close to sunset.
This time I only got the "Forward Vision Sensor Error" message once. Now I'm thinking, what are the chances the sun is causing flare on the vision sensors and this is reported as an anomaly?
I'd like to try under different light conditions to see if a cloudy sky makes a difference in the frequency of these messages. Also, I'd like to try after golden hour, with no direct sun available.
Has anyone experienced similar issues? While reading the forums I noticed a similar problem when the sensors had the plastic stickers on.
I'll keep you posted.
