Labroides
Flight distance : 9991457 ft
djiuser_wlXJ397MCB1I Posted at 1-1 15:22
Hello, I understand the policy for flights logs analysis. Now you can see the I’ve posted the flight logs and a couple of people pointed out that there was signal loss due to some obstruction and drone initiated RTH. Please help me understand why the drone didn’t land at home point and landed straight down on the hill even though there was enough hight clearance, no rock or any other object on my drone’s way home. Thanks!
You flew around behind a hill that was much higher than the spot where you launched.
At 10:23 you started to receive warnings about your signal being blocked, but instead of climbing or returning on the path you had taken, you continued until signal was completely lost.
Then Failsafe RTh was your only hope to bring the drone back.
But your RTH height was 98 feet and inadequate for the flight, so RTH wasn't going to climb high enough to clear the hill and the drone flew toward home at 316 ft relative to the launch point.
On the RTH path, the hill was approximately 262 feet higher than the launch point, which left only 60 feet clearance above the hil.
But any trees taller than 60 feet will have been obstacles in the path of the drone on RTH.
Just before signal was lost, the last three lines of your flight data show that the VPS was detecting something only 12 feet below the drone, indicating that the drone was approaching obstacles at or close to the level of the drone.
There is no data to show what happened after that, but it's not much of a stretch to work out that the drone, hit a tree and came down, shortly after losing signal.
This would have been easily preventable by not flying behind a hill or having set an appropriate RTH height to avoid the obstacle.
In summary the incident was caused by poor piloting.
