juan55
Flight distance : 577096 ft
It may be caused for the use of the filter itself…. Think about you are putting another reflection element after de camera lens and under some circumstances, mainly pointing to strong light sources, the light is reflecting between them back and forth, creating that flares and color beam paths. If they don’t have an anti reflection layer in the inner cristal (costly) it will reflect the light again back to the camera lens (probably reason of the two dots together). I have bought also the Fewer filters and I want to compare which ones are better in those conditions. |
