LV_Forestry
Flight distance : 4726654 ft
Latvia
rogiervdheide Posted at 8-31 23:44
Thanks so much. I am totally with you in regard to the second controller. I also fly the Ronin MX so that's a similar set up. I do not know how to "connect" the winch controller to the second ground controller but we need the range of the native system. So far I have seen winches with their own transmission + controller and their range is limited.
Thanks and I'll make myself known over here again when I have tips / experience!
You can just use a model radio control
https://hobbyking.com/en_us/turn ... _products_analytics
Puts the servo on an axis of the joysticks which remain in the center, by programming an exponential which gives a neutral / dead zone in the middle.
Alternatively, you can try with this:
https://www.banggood.com/3Pcs-12 ... CZ&rmmds=search
I tried both, both work. As for radio range, I don't know. I would say that the radio control has 1km without problem. the box in 433MHz much less I think. I have always used them on sight.
