I have just recieved a replacement Mini 3 Pro after my fly away. With the new one every flight I get a message asking me to check that I have the correct propellers attached. Is this normal ( i have checked, they are correct, screws are firm etc).
I dont remember seeing that when i last flew (few days ago), it there a box to choose not to see it again? perhaps youre seeing the beginners screen (just a guess)
You got a new unit. It's basically saying for you to give it a once over and check that everything is correctly attached and the props are installed in the correct direction. Mistakes happen and there's a chance someone in the factory didn't tighten up the props or they got installed incorrectly.
I would advise checking over your drone before each flight, especially checking that the motors smoothly rotate all in the same way. Dust and grit can ingress the motors causing friction and potentially jamming them.
Thanks every one, I had never seen it on the original drone only on the replacement. I started it up again today and this time noticed there is a box saying - don't show this again, I didn't notice it last time, but I also think it wasn't full screen last time and showed all 4 props. Anyway sorted now. Thanks again.
